200GE access switch (one 200GE port split into two 100GE ports), and 400GE ZR/ZR+ optical modules for interconnection at the maximum distance of 120 km
RG-S6580-24DC8QC |
Ports |
24 × 200GE ports (QSFP56) + 8 × 400GE ports (QSFP-DD) |
Expansion Modules |
Not supported |
Expansion Module Slots |
Two power supply module slots (1+1 redundancy) Six fan module slots (5+1 redundancy; the system needs at least 5 fan modules) |
Management Port |
Switching Capacity |
16.0 Tbps |
Packet Forwarding Rate |
5350 Mpps |
802.1Q VLAN |
4094 |
Dimensions |
RG-S6580-24DC8QC |
Dimensions (W × D × H) |
442 mm × 670.8 mm × 43.6 mm, 1 RU |
About 11 kg (including six fan modules and two power supply modules) |
RG-S6580-24DC8QC |
Power Input |
AC input: Rated voltage range: 200 VAC to 240 VAC Maximum voltage range: 90 VAC to 264 VAC Frequency: 50 Hz to 60 Hz Rated input current: 8 A HVDC input: Input voltage range: 192 VDC to 288 VDC Rated input current: 6.5 A |
Maximum Power Consumption |
850W |
RG-S6580-24DC8QC |
Temperature Alarm |
Temperature alarms and overheat protection |
Operating Temperature |
0ºC to 40ºC (32ºF to 104ºF) |
Storage Temperature |
–40°C to 70°C (-40 °F to 158 °F) |
Operating Humidity |
Working altitude |
Software Specifications |
RG-S6580-24DC8QC |
L2 Protocols |
IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), Jumbo Frame (9 KB) |
L3 Protocols (IPv4) |
IPv6 Basic Protocols |
IPv6 Features |
ACL |
ACL80、ACL-based redirection、IPv6 ACL、Extended/Standard IP ACL、Extended MAC ACL、Time-based ACL、Global ACL、Resource sharing in the case of applying an ACL on different physical ports or SVIs、ACL counter、ACL counter only、ACL logging、Displaying ACL resource usage、ACL-based re-marking、Expert-level ACL、IPv4 user-defined function(UDF) ACL、Configuring ACL counter-only globally、ACL matching against the inner 5-tuple of VXLAN packets、IPv6 UDF ACL、ACL matching against the inner 5-tuple of packets passing through the VXLAN |
Data Center Features |
Visualization |
gRPC sFlow sampling |
QoS |
HA Design |
Security Features |
Network foundation protection policy (NFPP), CPP, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, broadcast packet suppression, hierarchical user management |
Management Mode |
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and temperature alarm |
Other Protocols |
Specifications |
RG-S6580-24DC8QC |
Safety |
● GB 4943.1 |
● GB/T 9254.1 ● VCCI-CISPR 32:2016 |
Environment |
● Select the switch (installed with all fan and power supply modules).
● Select optical transceivers based on port requirements.
Product Model |
RG-S6580-24DC8QC |
24 × 200GE QSFP56 ports + 8 × 400GE QSFP-DD ports Two power slots and six fan slots The chassis is installed with two RG-PA1200I-F modules and six M1HFAN II-F fan modules. |
Product Model |
RG-PA1200I-F |
1200 W AC module (AC/240 V HVDC) |
Product Model |
M1HFAN II-F |
Fan module (front-to-rear ventilation) |
Product Model |
400G-QDD-SR8-MM850 |
400G-QDD-DR4-SM1310 |
400G-QDD-FR4-SM1310 |
Product Model |
100G-AOC-5M |
100G-AOC-10M |
100G-QSFP-SR-MM850 |
100G-QSFP-iLR4-SM1310 |
100G-QSFP-LR4-SM1310 |
100G-QSFP-ER4-SM1310 |
Contactați-ne
