Recommended for large-scale Spine-Leaf three-tier DCI scenarios, M-LAG/VSU/de-stacking for higher availability
RG-S6520-64CQ |
Ports |
64 × 100GE ports |
Expansion Module Slots |
Management Port |
Switching Capacity |
12.8 Tbps |
Packet Forwarding Rate |
4482 Mpps |
802.1Q VLAN |
4094 |
RG-S6520-64CQ |
Dimensions |
442 mm × 450 mm × 88 mm, 2 RU |
About 20 kg (including two power supply modules and three fan modules) |
RG-S6520-64CQ |
AC |
Rated voltage range: 100 VAC to 240 VAC Maximum voltage range: 90 VAC to 264 VAC Frequency: 50 Hz to 60Hz Rated Current: 11.7 A |
High-voltage DC |
Input voltage range: 192 VDC to 288 VDC Rated input voltage: 240 VDC Input current range: < 4.5 A |
Maximum Power Consumption |
600 W |
RG-S6520-64CQ |
Operating Temperature |
0 °C to 45 °C (32 °F to 113°F) |
Operating Humidity |
10% to 90%RH |
Working altitude |
Software Specifications |
RG-S6520-64CQ |
L2 Protocols |
L3 Protocols (IPv4) |
IPv6 Basic Protocols |
IPv6 Features |
IGMPv1, v2, v3、IGMP Host Behavior、Member Query and Response、Querier Election、IGMP Proxy、Multicast Static Routing、MSDP、PIM-DMv4(PIM-DM)、PIM-SMv4(PIM-SM/PIM-SSM/Enabling PIM on Layer-3 Subinterface)、PIM-SMv6、MLD v1 and v2、MLD Proxy、Enabling PIMv6 on Layer-3 Subinterface |
ACL |
Standard IP-based ACL、Extended MAC/IP-based ACL、Expert-level ACL、ACL 80、IPv6 ACL、When the same ACL is applied to different physical interfaces or SVIs, resources can be multiplexed.、ACL Logging、ACL Counter (Ingress and egress counters are supported in interface or global configuration modes)、ACL Re-marking、Global ACL、ACL-based Redirection、Displaying ACL Resources、Processing First Packet of TCP Handshake When Binding the ACL to Restrict SIP、Matching Against 5-Tuple of Pass-by VXLAN Inner IP Packets、The expert-level ACL supports matching the IP flag and DSCP fields of VXLAN inner packets、Ingress/Egress ACLs |
Data Center Features |
PFC, ECN, and other data center features M-LAG RDMA |
Visualization |
gRPC sFLOW sampling |
QoS |
Virtualization |
Virtual Switching Unit |
Cache Management |
Cache status monitoring and management, and identification of burst traffic |
HA Design |
GR for RIP/OSPF/BGP, BFD, REUP dual-link fast switching and RLDP unidirectional link detection, 1+1 power redundancy and fan redundancy, and hot swapping for all cards and power supply modules |
Security Features |
Network Foundation Protection Policy (NFPP), CPP, DDoS attack defense, illegitimate data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, ARP spoofing prevention, and ARP check |
Management Mode |
SNMP v1/v2/v3, Netconf, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, syslog, SPAN/RSPAN/ERSPAN, and configuration rollback |
Other Protocols |
Specifications |
RG-S6520-64CQ |
Safety |
● IEC 62368-1 ● EN 62368-1 ● NM EN 62368-1 ● NM CEI 62368-1 ● BS EN 62368-1 ● GB 4943.1 |
● EN 55032 ● EN 55035 ● NM EN 55035 ● BS EN55032 ● BS EN 55035 ● BS EN 61000-3-2 ● BS EN61000-3-3 ● EN IEC 61000-3-3 ● EN IEC 61000-3-2 ● NM EN 61000-3-2 ● NM EN 61000-3-3 ● EN 300 386 ● VCCI-CLSPR 32 ● GB/T 9254.1 |
Environment |
The configuration procedure for the RG-S6520 series switches is as follows:
● Select the switch.
● Select optical transceivers based on port requirements.
Product Model |
RG-S6520-64CQ |
64 × 100GE ports |
RG-PA800I-F |
M6520-FAN-F |
Product Model |
100G-QSFP-SR-MM850 |
100G-QSFP-LR4-SM1310 |
100G-QSFP-iLR4-SM1310 |
100G-QSFP-ER4-SM1310 |
100G-AOC-10M |
100G-AOC-5M |
Product Model |
40G-QSFP-SR-MM850 |
40G-QSFP-LR4-SM1310 |
40G-QSFP-LSR-MM850 |
40G-QSFP-LX4-SM1310 |
40G-QSFP-iLR4-SM1310 |
40G-AOC-30M |
40G-AOC-5M |
Contactați-ne
