RG-CS88-08 |
Supervisor module slots |
2 |
Line card slots |
6 |
Switching capacity |
9.6 Tbps |
Forwarding rate |
7200 Mpps |
442 x 465 x 441.7 mm (17.40 x 18.31 x 17.39 in) |
35.6 kg (78.48 lbs) |
Power and Consumption |
Power Supply |
RG-PA600I-F: 90 V to 180 V Power: 600 W; 180 V to 264 V Power: 600 W RG-PA1600I-F: 90 V to 180 V Power: 1200 W; 180 V to 264 V Power: 1600 W |
> 200,000 hours |
0°C to 45°C (32°F to 113°F) |
Operating noise |
27°C: 55.9 dB 45°C: 73.4 dB |
Temperature Alarm |
Supported |
RG-CS88 Series |
Feature |
Ethernet Switching |
STP, RSTP, and MSTP |
Super VLAN, Private VLAN |
Basic QinQ Flexible QinQ |
MPLS |
MPLS L3VPN |
MPLS 6VPE |
MPLS IPv6 |
IP Service |
ARP |
DHCP snooping |
DHCPv6 snooping |
Manual tunnel, automatic tunnel, ISATAP tunnel, and GRE tunnel |
IP Routing |
BGP4 and BGP4+ |
IPv4 and IPv6 VRF |
IPv4 and IPv6 PBR |
VRRP |
ECMP |
Policy-based routing |
IGMP v1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
MSDP |
MLD v1/v2 |
MLD snooping v1/v2 |
PIM-SMv6 and PIM-SSM v6 |
Port traffic rate limiting |
Multiple AAA modes |
Portal authentication, RADIUS, and TACACS+ login authentication |
DAI, port security, and IP source guard |
802.1x |
SAVI |
packets can be suppressed. |
SSHv2, providing encrypted security channels for user login |
REUP, RLDP, DLDP |
BFD |
Hot patch function and online installation of patches |
GR for OSPF/IS-IS/BGP |
BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/static routing |
SPAN, RSPAN, and ERSPAN |
sFLOW |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2/v3 |
RMON (1, 2, 3, 9) |
NETCONF |
Cloud and SON |
Console/AUX Modem/Telnet/SSH2.0 CLI configuration |
Fault alarm and auto-recovery |
System operation logging |
Green energy saving |
IEEE 802.3az Energy Efficient Ethernet |
RG-S7800C switches and supervisor engines |
RG-CS88-08 |
RG-CS88-08 switch, which can accommodate 6 service cards and 2 supervisor engines, and with 2 fans (Purchase at least one RG-PA600I-F/RG-PA1600I-F module.) |
CM88-CM |
CM88-CM new generation of high-performance engine. |
2.Power Modules and Fans
RG-PA600I-F |
Power module (support redundancy, AC, 600W) |
RG-PA1600I-F |
Power module (support redundancy, AC, 1600W) |
M08-FAN |
CS88-08 fan: Each M08-FAN tray consists of two fan modules and one fan monitoring card. It blows air to the outside for convection. (This is a default configuration for the switches.) |
3.Line Cards
Commercial-grade line cards |
CM88-48XS-H |
48 × 10GE optical ports (SFP+ and LC) |
CM88-8CQ-H |
8 × 100G Ethernet optical ports (QSFP28 and LC) |
CM88-48GT-H |
48 × GE electrical ports (RJ45) |
CM88-48SFP-H |
48 × GE optical ports (SFP+ and LC) |
Contactați-ne
