RG-SF2920U-4GT1MS-P |
RG-SF2920U-8GT1MS |
RG-SF2920U-8GT1MS-P |
Fixed port |
4 x 10/100/1000M auto-negotiation electrical ports, 1 x 1000M/2.5G SFP port, electrical ports 1–4 support PoE/PoE+ |
8 x 10/100/1000M auto-negotiation electrical ports 1 x 1000M/2.5G SFP optical port |
8 x 10/100/1000M auto-negotiation electrical ports 1 x 1000M/2.5G SFP+ port, electrical ports 1–8 support PoE/PoE+ |
Power module |
Fixed single AC power supply |
Fan module |
Fanless |
Fixed management port |
1 x console port |
1 x console port |
1 x console port |
Packet forwarding rate |
78 Mpps/126 Mpps |
80 Mpps/126 Mpps |
80 Mpps/126 Mpps |
Switching capacity |
432 Gbps/4.32 Tbps |
Number of MAC addresses |
16,000 |
1000 |
Ingress: 1500 Egress: 500 |
200 mm x 170 mm x 55 mm (7.87 in. x 6.69 in. x 2.17 in.) |
200 mm x 170 mm x 43.6 mm (7.87 in. x 6.69 in. x 1.72 in.) |
200mm x 170mm x 55 mm (7.87 in. x 6.69 in. x 2.17 in.) |
Weight (full configuration, including packaging) |
2.23 kg (4.92 lbs) |
1.98 kg (4.37 lbs) |
2.54 kg (5.60 lbs) |
MAC chip with built-in single-core CPU, 400 MHz |
Storage |
16 MB flash memory |
Data packet buffer |
8 MB |
8 MB |
8 MB |
Power and Consumption |
< 15 W (without PoE full load) < 60 W (with PoE full load) |
< 15 W |
< 15 W (without PoE full load) < 150 W (with PoE full load) |
Rated input voltage |
AC input: 200 V AC to 240 V AC @ 50 Hz to 60 Hz |
AC input: 180 V AC to 264 V AC |
40°C (104°F): > 300K |
Primary airflow |
Natural heat dissipation |
Weak-current box: 0°C to 40°C (32°F to 104°F) Desktop and wall: 0°C to 40°C (32°F to 104°F) Rack: (32°F to 113°F) |
Interface surge protection |
Power port: 6 kV (common/differential mode) Communication port: 8 kV (common mode) |
Operating altitude |
RG-SF2920-8GT2MG2XS |
RG-SF2920-16GT2MG2XS |
RG-SF2920-16GT2SFP |
Fixed port |
8 x 10/100/1000M auto-negotiation electrical ports 2 x 1000M/2.5G auto-negotiation ports 2 x 1/10G SFP+ ports |
16 x 10/100/1000M auto-negotiation electrical ports 2 x 1000M/2.5G auto-negotiation ports 2 x 1/10G SFP+ ports |
16 x 10/100/1000M auto-negotiation electrical ports 2 x 1G SFP optical ports |
Power module |
Fan module |
Fanless |
1 x console port |
1 x console port |
1 x console port |
84 Mpps/126 Mpps |
92 Mpps/126 Mpps |
82 Mpps/126 Mpps |
Number of global MAC addresses: 16,000 Number of static MAC addresses: 1,000 |
1,000 |
500 |
500 |
Ingress: 1,500 Egress: 500 |
210 mm x 235 mm x 55 mm (8.27 in. x 9.25 in. x 2.17 in.) |
2.75 kg (6.06 lbs) |
3.11 kg (6.86 lbs) |
MAC chip with built-in single-core CPU, 1 GHz |
Storage |
512 MB SDRAM 256 MB flash memory |
12 MB |
12 MB |
12 MB |
< 25 W |
< 25 W (without PoE full load) < 150 W (with PoE full load) |
< 25 W |
Primary airflow |
0°C to 50°C (32°F to 122°F) |
RG-SF2920-16GT2SFP-P |
RG-SF2920-8GT2MG2XS-P |
RG-SF2920-16GT2MG2XS-P |
Fixed port |
16 x 10/100/1000M auto-negotiation electrical ports 2 x 1G SFP ports Electrical ports 1–8 support PoE/PoE+ |
8 x 10/100/1000M auto-negotiation electrical ports 2 x 1000M/2.5G/5G auto-negotiation electrical ports 2 x 1G/10G SFP+ ports Electrical ports 1–8 support PoE/PoE+ |
16 x 10/100/1000M auto-negotiation electrical ports 2 x 1000M/2.5G/5G adaptive electrical ports 2 x 1G/10G SFP+ ports, Electrical ports 1-8 support PoE/PoE+ |
Power module |
Fan module |
Fanless |
1 x console port |
1 x console port |
1 x console port |
82 Mpps/126 Mpps |
84 Mpps/126 Mpps |
92 Mpps/126 Mpps |
1,000 |
500 |
500 |
3.1 kg (6.83 lbs) |
2.81 kg (6.20 lbs) |
3.12 kg (6.88 lbs) |
Storage |
12 MB |
12 MB |
12 MB |
< 25 W |
Primary Airflow |
RG-SF2920U-4GT1MS-P, RG-SF2920U-8GT1MS, RG-SF2920U-8GT1MS-P |
Feature |
Ethernet switching |
Jumbo frame length: 1,500 bytes |
802.3az EEE |
Maximum number of VLANs that can be created: 128 |
Interface-based VLAN assignment |
RSTP (IEEE 802.1w) |
LLDP |
IP service |
DHCP client |
Port protection |
Port security |
CPP |
Broadcast storm suppression |
Login authentication and password security |
SNTP |
CLI-based configuration and management not required, and visualized web management MQTT Syslog/Debugging |
RG-SF2920U-4GT1MS-P, RG-SF2920U-8GT1MS-P: ● IEEE 802.3af (15.4 W) and IEEE 802.3at (30 W) ● Energy-efficient power supply management modes ● Warm start to implement uninterrupted power supply |
RG-SF2920-16GT2SFP, RG-SF2920-16GT2SFP-P, RG-SF2920-8GT2MG2XS, RG-SF2920-8GT2MG2XS-P, RG-SF2920-16GT2MG2XS, RG-SF2920-16GT2MG2XS-P |
Feature |
Jumbo frame length: 9,216 bytes |
IEEE 802.3az EEE |
Private VLAN |
MAC VLAN MAC address-based, port-based, protocol-based, and IP subnet-based VLAN assignment |
Basic QinQ and flexible QinQ |
ERPS (G.8032) with switching time ≤ 50 ms |
IP service |
DHCP server, DHCP client, DHCP snooping, and DHCP snooping |
Neighbor Discovery (ND) |
IP routing |
Static blackhole routing |
RIP v1/v2 and RIPng |
OSPFv2 and OSPFv3 |
GR |
IGMPv1/v2/v3 snooping |
IGMP fast leave |
Extended IP ACLs |
Extended MAC ACLs |
Expert-level ACLs |
ACL80 and IPv6 ACLs |
ACLs on Layer 2 and Layer 3 interfaces |
Congestion management: SP, WRR, DRR, WFQ, SP+WRR, SP+DRR, SP+WFR, and SP+WFQ |
Rate limiting based on the inbound or outbound interface |
Eight queues on each port |
Rate limiting in each queue |
RADIUS and TACACS+ |
TACACS+ |
IEEE 802.1X authentication, MAC address bypass (MAB) authentication, and interface-based and MAC address-based 802.1X authentication |
SSHv1.5 and SSHv2.0 |
Global IP-MAC binding |
ICMP (discarding ICMP packets of which the rate exceeds the threshold on an interface) |
Port security |
BPDU guard |
ARP spoofing prevention |
DAI Portal authentication Login authentication and password security Unknown unicast suppression |
REUP |
Load balancing LACP dynamic aggregation The LACP priority, negotiation mode, and maximum number of ports that can be aggregated can be configured. Cross-VSU aggregate interface |
DLDP |
IPv4 VRRP v2/v3, IPv6 VRRPv3 |
GR for OSPF |
NMS and Maintenance |
RSPAN and ERSPAN |
Flow- and VLAN-based SPAN |
sFlow (network detection technology based on packet sampling, which is mainly used for traffic statistics and analysis in heavy-traffic scenarios) |
NTP and SNTP |
1:1 mirroring, N:1 mirroring, and 1:N mirroring Cross-device traffic mirroring SPAN, RSPAN, and ERSPAN |
FTP and TFTP |
SNMP v1/v2c/v3 |
RMON (1, 2, 3, 9) |
CLI (Telnet/console), Syslog/debugging, and web |
CWMP |
OpenFlow Special 1.0/1.3 |
Periodic and automatic restoration of the port in errdisable state |
Flow table analysis defined by all protocols Transmission of specified packets to the controller Configuring the controller's IP address and port Notifying port status changes to the controller |
RG-SF2920-16GT2SFP-P, RG-SF2920-8GT2MG2XS-P, and RG-SF2920-16GT2MG2XS-P: ● Electrical ports in compliance with IEEE 802.3af (15.4 W) and IEEE 802.3at (30 W) ● Automatic and energy-efficient power supply management modes ● Warm start to implement uninterrupted power supply ● Port priority |
4 x 10/100/1000M auto-negotiation electrical ports, 1 x 1000M/2.5G SFP port, fixed single AC power supply; electrical ports 1–4 support PoE/PoE+; maximum PoE output power: 45 W |
RG-SF2920U-8GT1MS |
8 x 10/100/1000M auto-negotiation electrical ports, 1 x 1000M/2.5G SFP port, fixed single AC power supply |
8 x 10/100/1000M auto-negotiation electrical ports, 1 x 1000M/2.5G SFP port, fixed single AC power supply; electrical ports 1–8 support PoE/PoE+; maximum PoE output power: 125 W |
16 x 10/100/1000M auto-negotiation electrical ports, 2 x 1G SFP ports, fixed single AC power supply |
16 x 10/100/1000M auto-negotiation electrical ports, 2 x 1G SFP ports, fixed single AC power supply; electrical ports 1–8 support PoE/PoE+; maximum PoE output power: 125 W |
8 x 10/100/1000M auto-negotiation electrical ports, 2 x 1000M/2.5G adaptive ports, 2 x 1/10G SFP+ ports, fixed single AC power supply |
8 x 10/100/1000M auto-negotiation electrical ports, 2 x 1000M/2.5G/5G auto-negotiation electrical ports, 2 x 1/10G SFP+ ports, fixed single AC power supply; electrical ports 1–8 support PoE/PoE+; maximum PoE output power: 125 W |
16 x 10/100/1000M auto-negotiation electrical ports, 2 x 1000M/2.5G adaptive ports, 2 x 1/10G SFP+ ports, fixed single AC power supply |
16 x 10/100/1000M auto-negotiation electrical ports, 2 x 1000M/2.5G/5G auto-negotiation electrical ports, 2 x 1/10G SFP+ ports, fixed single AC power supply; electrical ports 1-8 support PoE/PoE+; maximum PoE output power: 125 W |
Contactați-ne
