RG-S5310-24GT4XS-E
RG-S5310-24GT4XS-P-E
RG-S5310-48GT4XS -E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
24 x 10/100/1000 BASE-T ports
4 x 1G/10G SFP+ ports
48 x 10/100/1000 BASE-T ports
24 x 1000M SFP ports
48 x 1000M SFP ports
Management port
131 Mpps
131 Mpps
131 Mpps
4k/16k (authorized)
2k/8k (authorized)
8k/12k (authorized)
4.2 kg (9.26 lbs)
4.6 kg (10.14 lbs)
4.2 kg (9.26 lbs)
4.5 kg (9.92 lbs. )
1.2 GHz dual-core processor
BOOTROM
Flash
≤ 40 W
< 85 W (non-PoE)
< 810 W (PoE full load)
≤ 55 W
< 75 W (non-PoE)
< 1,570 W (PoE full load)
≤ 85 W
≤ 108 W
RG-PA70IB: 70 W
RG-PA150IB-F: 150 W
RG-PD150IB-F: 150 W
RG-PA70IB: 70 W
RG-PA150IB-F: 150 W
RG-PD150IB-F: 150 W
RG-PA70IB: 70 W
RG-PA150IB-F: 150 W
RG-PD150IB-F: 150 W
RG-PA150IB-F: 150 W
RG-PD150IB-F: 150 W
Left/Front-to-rear airflow
< 56.5 dB
< 57.4 dB
< 52.4 dB
< 58.3 dB
< 53.7 dB
< 53.7 dB
RG-S5310-E Series
OSPFv2, OSPFv3, and GR
Basic LACP
Inter-VSU AP
Hot swapping of power modules
RSPAN and ERSPAN
CLI (Telnet/Console)
1:1 mirroring
N:1 mirroring
1:N mirroring
VXLAN (authorized)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-PA70IB
70 W AC power module
RG-VXLAN-MPLS-ENTRY-LIC
Contactați-ne
Contactați-ne
Contactați-ne
Contactați-ne
