RG-S6150-24VS8CQ-X |
RG-S6150-48VS8CQ-X |
Basic Features |
Ports and Modules |
24 x 10G/25G SFP28 ports 8 x 40G/100G QSFP28 ports 4 fan modules 2 hot-swappable power supply modules |
48 x 10G/25G SFP28 ports 8 x 40G/100G QSFP28 ports 4 fan modules 2 hot-swappable power supply modules |
Management Ports |
One MGMT port, one console port, and one USB port (compliant with the USB 2.0 standard) |
Switching Capacity |
2.8 Tbps
4 Tbps
Packet Forwarding Rate |
1024Mpps/1680Mpps |
1024Mpps/2800Mpps |
Power Consumption (Full Load) |
270 W |
300 W |
Product Features |
VLAN |
4K 802.1Q VLAN Port-based VLAN Private VLAN Voice VLAN GVRP |
QinQ |
Basic QinQ Selective QinQ |
Link Aggregation |
LACP (802.3ad) |
Spanning Tree Protocols |
STP, RSTP, MSTP |
DHCP |
DHCP server DHCP client DHCP snooping DHCP relay IPv6 DHCP server IPv6 DHCP snooping IPv6 DHCP client IPv6 DHCP relay |
IPv6 Basic Protocols |
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, Stateless Auto Configuration, Path MTU Discovery |
IP Routing |
SVI: 4k supported
RIP, RIPng OSPFv2, OSPFv3, IS-ISv4, IS-ISv6 BGP4, BGP4+ ECMP Packet-based and flow-based load balancing MCE |
IGMP v1, IGMPv2, IGMPv3, IGMP proxy IGMP v1/v2/v3 snooping IGMP filtering, IGMP immediate leave PIM-DM, PIM-SM, PIM-SSM MLD snooping, MLD PIM for IPv6 |
MPLS |
MPLS L3VPN |
ACL & QoS |
ACL |
The following flexible and diversified hardware ACLs are supported: Standard IP ACLs (IP-based hardware ACLs) Extended IP ACLs (hardware ACLs based on IP addresses or TCP/UDP port IDs) MAC-based extended ACLs (hardware ACLs based on source MAC addresses, destination MAC addresses, and optional Ethernet type) Time-based ACLs Expert-level ACLs (hardware ACLs based on flexible combinations of the Ethernet type, MAC address, IP address, TCP/UDP port ID, protocol type, and time) ACL 80 IPv6 ACLs |
QoS |
Port traffic identification Port traffic rate limiting 802.1p/DSCP/ToS traffic classification Eight priority queues per port SP, DRR, SP+DRR, RED/WRED queue scheduling mechanisms |
Security Features |
3-tuple binding (IP address, MAC address, and port) 3-tuple binding (IPv6 address, MAC address, and port) Filtering of invalid MAC addresses Port- and MAC-based 802.1x authentication MAB authentication Portal authentication and Portal 2.0 authentication ARP check DAI ARP packet rate limiting Gateway ARP spoofing prevention Broadcast storm suppression Hierarchical management of administrators and password protection RADIUS and TACACS+ AAA (IPv4/IPv6) for device login management SSH BPDU guard IP source guard CPP, NFPP Port protection |
Management Features |
SNMP, CLI (Telnet/Console), RMON, SSH, Syslog, NTP/SNTP, SNMP over IPv6, IPv6 MIB support for SNMP, SSHv6, Telnet v6, FTP/TFTP v6, DNS v6, NTP for v6, Traceroute v6 sFlow, which utilizes the random sampling technology to conduct flow information sampling on the traffic of a switch. MACC-based management |
High Reliability |
VSU (virtualizing multiple devices into one device) GR for RIP, OSPF, BGP, and other routing protocols BFD ERPS (G.8032) REUP RLDP 1+1 power redundancy Hot swapping of power modules |
Physical Features |
Power Supply |
AC input: Rated voltage range: 100 V AC to 240 V AC Maximum voltage range: 90 V AC to 264 V AC Frequency: 50/60 Hz
HVDC input: Rated voltage: 240 V DC Maximum voltage range: 192 V DC to 288 V DC |
Fan |
3+1 redundancy, at least three fan modules are required for the system. Fan speed regulating and fault alarming |
Temperature Alarming |
Supported |
Temperature |
Operating temperature: 0°C to 45°C (32°F to 113°F) Storage temperature: –40°C to 70°C (–40°F to 158°F) |
Humidity |
Operating humidity: 10% to 90% (non-condensing) Storage humidity: 5% to 95% |
RG-PA550I II-F |
VG-SFP-SR-MM850 |
VG-SFP-SR-MM1310 |
VG-SFP-AOC5M |
40G-QSFP-SR-MM850 |
40G-QSFP-LR4 SM1310 |
40G-AOC-5M |
40G-AOC-10M |
100G-QSFP-SR-MM850 |
100G-QSFP-LR4-SM1310 |
100G-AOC-1M |
100G-AOC-5M |
100G-AOC-10M |
Contactați-ne
