RG-S5760C-24GT8XS-X |
RG-S5760C-48GT4XS-X |
RG-S5760C-24SFP8GT8XS-X |
RG-S5760C-48SFP4XS-X |
RG-S5760C-48GT4XS-HP-X |
Fixed port |
24 x 10/100/1000 Mbps electrical ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 2 x power supply module slots |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 2 x power supply module slots |
24 x 1000 Mbps SFP ports (Ports 1-16 are 100/1000 Mbps SFP ports), 8 x 10/100/1000 Mbps combo ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 2 x power supply module slots |
48 x 1000 Mbps SFP ports, 4 x 1GE/10GE SFP+ ports, 3 x modular fans, 2 x power supply module slots |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 2 x power supply module slots, supporting PoE/PoE+ |
Fan module |
Two built-in fan modules Fan speed regulating and fault alarms |
Three pluggable fan modules |
Two pluggable fan modules |
Power module |
Two power modules The switch can be powered on by either one or dual power modules. If both power modules are used, the switch works in the power redundancy mode. |
Management port |
One MGMT port, one console port, and one USB port, compliance with the USB2.0 standard |
Expansion slot |
Two expansion slots are reserved for expansion modules and supervisor modules. One expansion slot is reserved on the RG-S5760C-48GT4XS-HP-X and RG-S5760C-48SFP4XS-X. |
Packet forwarding rate |
426Mpps/600Mpps |
406Mpps/600Mpps |
426Mpps/600Mpps |
406Mpps/600Mpps |
406Mpps/600Mpps |
Switching capacity |
880Gbps/7.92Tbps |
880Gbps/7.92Tbps |
880Gbps/7.92Tbps |
880Gbps/7.92Tbps |
880Gbps/7.92Tbps |
Number of MAC addresses |
64,000 |
64,000 |
64,000 |
64,000 |
64,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
4,000 mmu-enhance: 3,000 |
14,000 |
14,000 |
14,000 |
14,000 |
14,000 |
2,000 mmu-enhance: 1,500 |
In: 7,000 Out:1,500 |
Number of IGMP groups |
4,000 |
Number of MLD groups |
1,000 |
Number of VSU members |
8 |
440 mm x 340 mm x 44 mm (17.32 in. x 13.39 in. x 1.73 in.) |
442 mm x 420 mm x 43.6 mm (17.40 in. x 16.54 in. x 1.72 in.) |
4.4 kg (9.70 lbs) |
4.5 kg (9.92 lbs) |
4.3 kg (9.48 lbs) |
5.3 kg (11.68 lbs) |
5.5 kg (12.13 lbs) |
1.2 GHz dual-core CPU |
Storage |
Flash memory: 4 GB SDRAM: 1 GB |
Flash memory: 4 GB SDRAM: 2 GB |
Data packet buffer |
1.2MB |
Power and Consumption |
< 60 W (excluding expansion modules) < 85 W (including expansion modules) |
< 70 W (excluding expansion modules) < 95 W (including expansion modules) |
< 77 W (excluding expansion modules) < 102 W (including expansion modules) |
< 105 W (excluding expansion modules) < 125 W (including expansion modules) |
Without PoE load: ≤ 110 W With PoE full load: ≤ 1,590 W |
Maximum output power |
RG-PA70IB: 70 W RG-PA150I-F: 150 W RG-PA150IB-F: 100 V to 240 V, 150 W RG-PD150IB-F: 48 V DC to 60 V DC, 150 W |
RG-PA600I-P-F: 600 W (PoE: 370 W) RG-PD600I-P-F: 600 W (PoE: 370 W) RG-PA1000I-P-F: 176 V AC to 290 V AC, 1000 W; 90 V AC to 176 V AC, 930 W (PoE: 740 W) |
Rated input voltage |
AC input Rated voltage range: 100 V to 240 V Frequency: 50 Hz/60 Hz HVDC input: Rated voltage range: 240 V LVDC input: Rated voltage range: 48 V DC to 60 V DC |
AC input Rated voltage range: 200 V to 240 V Frequency: 50 Hz/60 Hz DC input: Rated voltage range: 48 V to 60 V |
AC input Maximum voltage range: 90 V to 264 V HVDC input: Maximum voltage range: 192 V to 288 V LVDC input: Maximum voltage range: 36 V DC to 75 V DC |
AC input Maximum voltage range: 176 V to 264 V DC input: Maximum voltage range: 38 V to 75 V |
AC input Maximum voltage range: 90 V to 264 V DC input: Maximum voltage range: 36 V to 75 V |
120 years |
110 years |
94 years |
90 years |
95 years |
Primary Airflow |
Air intake from left and front panel, and air exhaust from right |
Front-to-rear airflow |
0°C to 45°C (32°F to 113°F) V1.X+M5000X4XS2CQ: 0 to 40°C (32°F to 104°F) |
0°C to 45°C (32°F to 113°F) |
10% to 90% (non-condensing) |
5% to 95% (non-condensing) |
Operating altitude |
0 m to +5,000 m (0 ft. to +16404.20 ft.) |
Operating noise |
45°C (113°F): 56.2 dB |
45°C (113°F): 57.9 dB |
45°C (113°F): 57.1 dB |
27°C (80.6°F): 50 dB 45°C (113°F): 65 dB |
27°C (80.6°F): 53 dB 45°C (113°F): 68 dB |
Interface surge protection |
RG-S5760-X Series |
Feature |
Ethernet switching |
Super-VLAN and private VLAN |
STP, RSTP, and MSTP |
LACP (IEEE 802.3ad) |
IP service |
ARP |
DHCP snooping |
DHCPv6 client, DHCPv6 server, and DHCPv6 relay |
DHCPv6 snooping |
IPV6 addressing, ICMPv6, Stateless Address Auto-configuration (SLAAC), and path MTU discovery |
IP routing |
BGP4 and BGP4+ |
ECMP |
IPv4 and IPv6 VRF |
IPv4 and IPv6 PBR |
IGMP v1/v2/v3 and IGMP proxy |
IGMP v1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
MSDP |
MLD snooping v1/v2 |
PIM-SMv6 and PIM-SSM v6 |
MPLS |
MPLS L3VPN |
Port traffic identification |
Port traffic rate limiting |
AAA |
RADIUS and TACAS+ |
Port-based and MAC address-based 802.1X authentication |
HTTPS |
SSHv1 and SSHv2 |
Global IP-MAC binding |
SAVI |
3-tuple binding (IP address, MAC address, and port) 3-tuple binding (IPv6 address, MAC address, and port) Filtering of unauthorized MAC addresses MAC address bypass (MAB) authentication Portal authentication and Portal 2.0 authentication ARP check Dynamic ARP Inspection (DAI) ARP packet rate limiting Gateway ARP anti-spoofing Broadcast storm suppression Hierarchical management of administrators and password protection AAA for device login management MAC Authentication Bypass (SSH) BPDU guard Port protection |
REUP, RLDP, and DLDP |
GR for RIP, OSPF, BGP, and other routing protocols |
BFD |
1+1 power module redundancy |
VSU |
NMS and mainten ance |
SPAN, RSPAN, and ERSPAN |
sFlow |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2c/v3 |
RMON (1, 2, 3, 9) |
SSHv1 and SSHv2 |
Syslog |
NETCONF |
CWMP (TR-069) |
CLI (Telnet/Console), SNMP over IPv6, IPv6 MIB support for SNMP, SSHv6, Telnet v6, FTP/TFTP v6, DNS v6, NTP for IPv6, and Traceroute v6 |
RG-S5760C-48GT4XS-HP-E: IEEE 802.3af and 802.3at, uninterruptible power supply upon hot start, and port priority |
VXLAN |
With VXLAN, a Layer 2 logical network can be built based on a Layer 3 network through software upgrade. |
RG-S5760-X Series |
Organization |
Standards and Protocol |
IETF |
RFC 1157 A Simple Network Management Protocol (SNMP) RFC 1305 Network Time Protocol Version 3 (NTP) RFC 1349 Internet Protocol (IP) RFC 1350 TFTP Protocol (revision 2) RFC 1519 CIDR RFC 1591 Domain Name System Structure and Delegation RFC 1643 Ethernet Interface MIB RFC 1757 Remote Network Monitoring (RMON) RFC 1812 Requirements for IP Version 4 Router RFC 1901 Introduction to Community-based SNMPv2 RFC 1902-1907 SNMP v2 RFC 1918 Address Allocation for Private Internet RFC 2131 Dynamic Host Configuration Protocol (DHCP) RFC 2132 DHCP Options and BOOTP Vendor Extensions RFC 2571 SNMP Management Frameworks RFC 2863 The Interfaces Group MIB RFC 2925 Definitions of Managed Objects for Remote Ping, Traceroute, and Lookup Operations (Ping only) RFC 3046 DHCP Option82 RFC 3417 (SNMP Transport Mappings) RFC 3418 Management Information Base (MIB) for the Simple Network Management Protocol (SNMP) RFC 4022 MIB for TCP RFC 768 User Datagram Protocol (UDP) RFC 783 TFTP Protocol (revision 2) RFC 792 Internet Control Message Protocol (ICMP) RFC 793 Transmission Control Protocol (TCP) RFC 813 Window and Acknowledgement Strategy in TCP RFC 815 IP datagram reassembly algorithms RFC 826 Ethernet Address Resolution Protocol (ARP) RFC 854 Telnet Protocol RFC 959 File Transfer Protocol (FTP) RFC 1058 Routing Information Protocol (RIP) RFC 1583 OSPF Version 2 RFC 1981 Path MTU Discovery for IP version 6 RFC 1997 BGP Communities Attribute RFC 2236 IGMP RFC 2328 OSPF Version 2 RFC 2385 Protection of BGP Sessions via the TCP MD5 Signature Option RFC 2439 BGP Route Flap Damping RFC 2460 Internet Protocol, Version 6 (IPv6) RFC 2461 Neighbor Discovery for IP Version 6 (IPv6) RFC 2462 IPv6 Stateless Address Auto configuration RFC 2463 Internet Control Message Protocol for IPv6 (ICMPv6) RFC 2545 Use of BGP 4 Multiprotocol Extensions for IPv6 Inter Domain Routing RFC 2711 IPv6 Router Alert Option RFC 2787 Definitions of Managed Objects for the Virtual Router Redundancy Protocol RFC 2865 Remote Authentication Dial In User Service (RADIUS) RFC 2918 Route Refresh Capability for BGP 4 RFC 2934 Protocol Independent Multicast MIB for IPv4 RFC 3065 Autonomous System Confederation for BGP RFC 3101 OSPF Not so stubby area option RFC 3137 OSPF Stub Router Advertisement sFlow RFC 3509 Alternative Implementations of OSPF Area Border Routers RFC 3513 IP Version 6 Addressing Architecture RFC 3575 IANA Considerations for RADIUS RFC 3579 RADIUS Support For EAP RFC 3623 Graceful OSPF Restart RFC 3768 VRRP RFC 3810 Multicast Listener Discovery Version 2 (MLDv2) for IPv6 RFC 3973 PIM Dense Mode RFC 4271 A Border Gateway Protocol 4 (BGP 4) RFC 4273 Definitions of Managed Objects for BGP 4 RFC 4360 BGP Extended Communities Attribute RFC 4456 BGP Route Reflection: An Alternative to Full Mesh Internal BGP (IBGP) RFC 4486 Subcodes for BGP Cease Notification Message RFC 4552 Authentication/Confidentiality for OSPFv3 RFC 4724 Graceful Restart Mechanism for BGP RFC 4750 OSPFv2 MIB partial support no SetMIB RFC 4760 Multiprotocol Extensions for BGP 4 RFC 4940 IANA Considerations for OSPF RFC 5065 Autonomous System Confederation for BGP RFC 5187 OSPFv3 Graceful Restart RFC 5340 OSPFv3 for IPv6 RFC 5492 Capabilities Advertisement with BGP 4 RFC 6620 FCFS SAVI |
IEEE |
IEEE 802.2 Logical Link Control IEEE 802.1ab Link Layer Discovery Protocol IEEE 802.1ad Provider Bridges IEEE 802.1ax/IEEE802.3ad Link Aggregation IEEE 802.1D Media Access Control (MAC) Bridges IEEE 802.1Q Virtual Bridged Local Area Networks (VLAN) IEEE 802.3ad Link Aggregation Control Protocol (LACP) IEEE Std 802.3x Full Duplex and flow control IEEE 802.1D Spanning Tree Protocol IEEE 802.1s Multiple Spanning Tree Protocol IEEE 802.1w Rapid Spanning Tree Protocol IEEE 802.3bt Power over Ethernet |
Electromagnetic Compatibility (EMC) Standards: ✓CISPR 22/EN 55032 (Conducted and Radiated Emissions) ✓EN 55035 (Immunity) ✓IEC/EN 61000-4-2 or ANSI/ESD S20.20 (Electrostatic Discharge - ESD) ✓IEC/EN 61000-4-3 (Radio Frequency Electromagnetic Field) ✓IEC/EN 61000-4-4 (Electrical Fast Transient -EFT) ✓IEC/EN 61000-4-5 (Surge Immunity) ✓IEC/EN 61000-4-6 (Radio Frequency Common Mode) ✓IEC/EN 61000-4-11 (Voltage Dips and Interruptions) ✓IEC/EN 61000-3-2(Voltage Dips and Interruptions) ✓IEC/EN 61000-3-2 (Voltage Dips and Interruptions) • Safety Standards: ✓IEC 60950/EN 62368 ✓IEC 60068 ✓RoHS or WEEE (Environmental) |
24 x 10/100/1000 Mbps electrical ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x built-in fixed fans, 2 x power module slots Purchase at least one RG-PA150IB-F module. |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x built-in fixed fans, 2 x power module slots (Purchase at least one RG-PA150IB-F module.) |
24 x 10/100/1000 Mbps SFP ports (Ports 1-16 are 100/1000 Mbps SFP ports), 8 x 10/100/1000 Mbps combo ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x built-in fans, 2 x power module slots (Purchase at least one RG-PA150IB-F module.) |
48 x 1000 Mbps SFP ports, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x modular fans, 2 x power module slots Purchase at least one RG-PA150IB-F module. |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x modular fans, 2 x power module slots Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F/RG-PD600I-P-F module. |
M5000X-4XS2CQ |
4 x 10GE SFP+ ports and 2 x 100GE QSFP28 ports |
M5000X-4QXS* |
4 x 40GE QSFP+ ports |
RG-PA150IB-F |
150 W AC power module |
RG-PA600I-P-F |
600 W PoE AC power module |
RG-PA1000I-P-F |
1000 W PoE AC power module |
RG-PD600I-P-F |
600 W PoE DC power module |
MINI-GBIC-ZX50-SM1550 |
MINI-GBIC-ZX100-SM1550 |
10GE LC module (62.5/125 μm: 33 m (108.27 ft.); 50/125 μm: 66 m (216.54 ft); transmission for 300 m (984.25 ft.) when modal bandwidth is 2000 MHz*km), applicable to SFP+ ports |
10GE SFP+ optical cable, 1 m (3.28 ft.), including one cable and two interface modules |
10GE SFP+ optical cable, 3 m (9.84 ft.), including one cable and two interface modules |
10GE SFP+ optical cable, 5 m (16.40 ft.), including one cable and two interface modules |
Contactați-ne
